Auto trans slipping bad in 1st and second not as bad in other gears?? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-27-2014, 11:17 AM Thread Starter
F250_STROKER_7.3's Avatar
Quoted: 7 Post(s)
I have a 2000 model f250 with a 7.3
It has 230k miles
I now Travel a lot
Had the truck for 7 years now
A couple years ago while towing it overheated a couple times and puked trans fluid out the top
I put a 6.0 trans cooler on it once I found the cause
For 5 years the truck had edge evolution programmer
Then last year I went to php hydra chip
I don't run the truck to hard but lately I 2nd and a lil in 1st the trans is slipping
If I get on it it don't accelerate at all...rpm will reach 3k then I let out and stay under1500 rpm and it will slowly gain speed
Is my whole trany going or not??
Btw until trans gets warm it does not want to go in overdrive
I've never seen the trans reach over 160 since 6.0 cooler was installed and usually stays at 115 to 125
F250_STROKER_7.3 is offline
post #2 of 10 Old 05-27-2014, 07:53 PM
heykw's Avatar
Just out of curiosity what 6.0 Trans cooler do you have?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 10 Old 05-27-2014, 10:39 PM Thread Starter
Quoted: 7 Post(s)
It was just a factory one
Not sure what year tho
post #4 of 10 Old 05-28-2014, 01:30 AM
Rodslinger's B1TCH
Sounds like low line pressure to me. Did it start slipping right after the hydra install?
An aftermarket valve body MIGHT fix your problems.
The edge evolution electronically raises the line pressure to give you hard shifting. Your hydra tunes are probably running at stock or near stock line pressure which is causing the slippage.
steve604 is offline
post #5 of 10 Old 05-29-2014, 05:02 PM Thread Starter
Quoted: 7 Post(s)
No it just started slipping lately
It usually only does it when I get on it
But every once in awhile it slips real bad when just normally pulling out
post #6 of 10 Old 06-01-2014, 11:52 AM Thread Starter
Quoted: 7 Post(s)
Ok guys I got the code p0732 2nd gear ratio error
Cleared the code and turn the php hydra back to 80 DD
And it has acted normal for a day or two...is my problem gone or going to return?!?!?!?
post #7 of 10 Old 06-01-2014, 11:36 PM
Rodslinger's B1TCH
wierd. might be a sensor or a problem with the solenoid pack. no way to tell until the problem comes back.
if it comes back, i would try replacing the solenoid pack to see if that fixes it.
steve604 is offline
post #8 of 10 Old 11-29-2014, 06:41 PM
Did the problem come back or did you fix it?
Donman is offline
post #9 of 10 Old 12-11-2014, 04:15 PM Thread Starter
Quoted: 7 Post(s)
It got to the point where I couldn't hardly drive it in traffic or anywhere besides interstate due to it being like it was in neutral in low gears, smelt fluid and it smelt toasted and ended up pulling trans and wanted to do a zf6 swap like I always dreamed of having but of coarse I needed this truck as it is my DD and couldn't find everything near me for the swap therefore I ended up going with the 4r100HD from ford, 2700$ later I have a new trans that shifts great and smooth lol
post #10 of 10 Old 12-11-2014, 05:47 PM
Ya my clutch discs were bad. I was having shifting trouble to. I was trying to figure out my problem. But after getting a couple shops opinion I got mine rebuilt. Just got it back on Tuesday.
Donman is offline
