Transmission problem, need advice! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-23-2014, 02:24 PM Thread Starter
Okay, I have a 2002 F250 with a 7.3. This morning I went out to start my truck and it wouldn't start, had power (radio, gauges, etc) so after I thought for a few minutes I threw it in neutral and it started. I thought it was weird but whatever. So when I got to work I went to put it in park and it won't go in! Just stops in reverse like the gear shifter hit a wall. I have not had any symptoms of a failing transmission so I am perplexed by this sudden failure. Any advice would be welcome before I go stick it in the shop and rack up a huge bill. Thank you.
Reaper1675 is offline
post #2 of 4 Old 05-23-2014, 06:39 PM
Quoted: 21 Post(s)
Is the shifter sloppy? Or is accurate and tight? The reason I ask ..wondering if its a linkage issue?
The Next Level is offline
post #3 of 4 Old 05-23-2014, 08:17 PM Thread Starter
The shift is not sloppy at all. It's tight and has had no issues up to this point. It just stops in reverse and won't go up into park
post #4 of 4 Old 06-21-2014, 06:48 PM
It could be your neutral safety switch. if its not that. then its your linkage.
e99 7.3 Crew Cab 4x4
6.0 Trans Cooler
06 Mirrors (wired all but heat) 06 step bars
36" Tires/factory 06 18" rims
PHP Chip/Glow Shift Gauges
Crank Case Vent Mod
600k miles and still running strong.
AdamCap is offline
