transmission temps - Ford Powerstroke Diesel Forum
post #1 of 35 Old 05-16-2014, 03:57 PM Thread Starter
transmission temps
Hello everyone its been a long time since ive been on here and for that I apologize.
First off I need to update my sig bit dont really have time right now. New mods on the truck are lift kit running 38 inch toyos.
My problem is running around town empty with no load and not hot rodding around my trans temps are running around 180 degrees I know that is way to hot with the outside temp being 82 degrees.
I know I need to do a mod of some sort for my trans cooler but even without that I don't think I should be running that hot. I did notice a little bit of leaking tranny fluid from around the inspection plate. Is there a way to check and see if the current cooler lines are plugged and the fluid going thru the bypass? Or do you have any other ideas?
Thanks in advance.
2000 f-250
short box extended cab
4 inch exhaust
K&N intake
TS performance chip
8 inch rough country lift
38 toyo mud terrains
DIY boost fooler
glow shift A pillar gauges(poke fun I dont care they have treated me well so far)
Latest rig 2009 cc lb
s&b intake
dpf/cat delete
spartan tuned
the2ndtinman is offline
post #2 of 35 Old 05-16-2014, 04:34 PM
Quoted: 27 Post(s)
actually IMO that's not to far off. I run about 155-160 in town and im on 33's. in town on 38's with stock gearing I can see 180. IIRC 60-100 degrees above ambient temp is good. if you were around 200 that's when I'd start worrying.
DISCLAIMER: im not a transmission guru
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #3 of 35 Old 05-16-2014, 05:56 PM Thread Starter
Im worried about once it gets in the 100s here.
2000 f-250
4 inch exhaust
K&N intake
TS performance chip
DIY boost fooler
s&b intake
dpf/cat delete
spartan tuned
post #4 of 35 Old 05-16-2014, 06:24 PM
Quoted: 27 Post(s)
if a cooler line was plugged wouldn't it puke out some trans fluid rather than leak just a little?
-Kris
4'' straight pipe
DIY 6637
38r
post #5 of 35 Old 05-16-2014, 07:11 PM
Vannnce's Avatar
Quoted: 13 Post(s)
on a stock cooler, i dont see anything out of the ordinary there. get you a 6.0 cooler.
Mine stays pretty much exactly 80 degrees hotter than ambient air temps with a tru cool cooler
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #6 of 35 Old 05-17-2014, 04:18 PM Thread Starter
Ok today outside temp is onky around 72 and driving around easy temps got to around 210.
2000 f-250
4 inch exhaust
K&N intake
TS performance chip
DIY boost fooler
s&b intake
dpf/cat delete
spartan tuned
post #7 of 35 Old 05-18-2014, 11:46 AM
Quoted: 27 Post(s)
How's the fluid look?
-Kris
4'' straight pipe
DIY 6637
38r
post #8 of 35 Old 05-28-2014, 04:52 PM Thread Starter
Fluid looks ok doesnt smell burnt.
2000 f-250
4 inch exhaust
K&N intake
TS performance chip
DIY boost fooler
s&b intake
dpf/cat delete
spartan tuned
post #9 of 35 Old 06-21-2014, 07:46 PM
do the 6.0 Transmission swap. it will take you about 2-6 hours depending on how much yu know about your truck.
It took me about 4 hours. and i was slacking off. I have never seen over 165 on my transmission temp and its gotten above 110 here in NC. I did see 160 with about 7500lbs on my trailer and it was around 95 outside.
other then that my best friend has the small 7.3 transmission cooler in his truck and he sees around 200-210 all day and he has yet to have a problem. so i honestly wouldnt worry too much about it till about 250 then you need to pull over.
Im also not a guru on transmission just telling you my personal experience.
e99 7.3 Crew Cab 4x4
6.0 Trans Cooler
06 Mirrors (wired all but heat) 06 step bars
36" Tires/factory 06 18" rims
PHP Chip/Glow Shift Gauges
Crank Case Vent Mod
600k miles and still running strong.
AdamCap is offline
post #10 of 35 Old 06-21-2014, 09:53 PM
Quoted: 27 Post(s)
250 is to hot. Iirc 230 than pull over and high idle in park or neutral. And did u mean 6.0 trams cooler?
-Kris
4'' straight pipe
DIY 6637
38r
