Trans help - Ford Powerstroke Diesel Forum
post #1 of 1 Old 05-07-2014, 05:28 PM Thread Starter
mxracer511's Avatar
Quoted: 4 Post(s)
Send a message via AIM to mxracer511 Send a message via Yahoo to mxracer511
Trans help
I've done some reading already but just want a general consensus 02 7.3 pulling a trailer and from what I was told got a bit hot and o/d lite started to flash consistently and still does even after unhooked n let cool down also feels like it's slipping a bit, scanned it for codes and got p0713 trans fluid temp sensor high input, p0750 shift solenoid a fail, p0743 tcc system electrical fault, p0782 2-3 shift error, p0741 torque converter clutch system stuck off,p1105 dual alternator upper fault, so is it pretty solid that the tranny is probably dead?
99 7.3, 6" stacks, 37x13.5 km2s, ev boost, trans temp and egt gauges, 6637 intake, tw tunes, cnc fab 4 line fuel feed kit, hpx, boost fooler, john woods valve body, triple disc billet tq conv, swamps idm, MB hoop, comp cams 910-16 valve springs .030 shims, smith brothers pushrods and PIS 250/200's, PMF stage 2 gusseted trac bars, 4" icon lift
mxracer511 is offline
