Quick PCM question regarding auto to manual swap - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-21-2014, 10:26 AM Thread Starter
jshalala's Avatar
2001 7.3 auto truck now swapped to a ZF5 manual trans. Truck runs and drives.
Stutters under acceleration, pretty sure it is still on the auto pcm. When I picked it up it had a TS 6 position chip in it.
Pulled the chip and sold it as I didnt want to deal with unknown tunes in a higher mileage PMR truck.
Now that the chip is removed the truck runs pretty bad at lower rpms, smooths out at higher rpms but still stutters under acceleration.
I am planning to send my PCM to PHP to have them reflash it to manual configuration.
My question: will a manual PCM screw up anything in a formally auto truck? My cruise does not work, but I dont really care.
Will it affect the shift on the fly 4x4 operation? Any wiring changes that I would need to do?
I am hoping I could just have the PCM flashed then not have to deal with any other running issues related to the swap.
2003 Ford F250 6.0 powerstroke 4x4.
ZF6 manual trans, ext cab short bed
deleted, 4 inch exhaust, gauges, traction bars
16x10 Weld wheels wrapped in 33s
Early 1999 Ford F250 7.3 Powerstroke 4x4
Crew cab short bed
straight pipe, intake
jshalala is offline
post #2 of 3 Old 04-23-2014, 08:20 AM Thread Starter
jshalala's Avatar
BUMP! Any ideas?
Crew cab short bed
jshalala is offline
post #3 of 3 Old 04-23-2014, 08:48 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Yup it can be flashed to run a manual truck with no problem
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
