4r100 everything is neutral? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-15-2014, 08:22 AM Thread Starter
Demonstroker's Avatar
So last night I was sitting at a red light and when it turned green I let off the brake and pressed the gas, nothing happened so I tried shifting through all the gears even reverse, but it's like everything was neutral, although I can hear the truck shift and the Rpms go down a bit when I put it into drive, so I tried turning the truck off and on and the same thing, so I had to get towed home, I also noticed it's leaking oil from the transmission... Any ideas what it it might be?
Demonstroker is offline
post #2 of 5 Old 04-15-2014, 08:33 AM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
Could the fluid just be low because of the leak?
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
Demonstroker (04-15-2014)
post #3 of 5 Old 04-15-2014, 09:34 AM Thread Starter
You know I didn't think about that... Is it possible that the fluid got so low it won't let it engage gears? It has never leaked before ever I would notice kn my driveway but last night it had a a somewhat huge puddle underneath all of a sudden like it just all came out out once or something?
post #4 of 5 Old 04-15-2014, 09:38 AM
hansel's Avatar
Quoted: 94 Post(s)
Hopefully you are just low on fluid, when mine did what your's is doing mine transmission was toast
Working on minute, broken the next with "NO" warning, just broke!!! I did get lucky it happened in my driveway.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #5 of 5 Old 04-15-2014, 09:52 AM Thread Starter
I'm going to post a picture from where it was leaking from and hopefully you guys will have some ideas to help me from what it is I'll post the picture around 4 o clock but hopefully it's just the fluid and either way I'll have to figure out why it's leaking.... Hopefully it's just a broken seal from pressure washing underneath like a dum ***... Idk why I did it
