Need a cure - Ford Powerstroke Diesel Forum
Old 12-09-2008, 02:30 AM
Need a cure
When driving it revs high the I have to let off the throttle for it to change gears. The OD light flashes every once in a while. One code was 1:2 gear ratio error. the other code was 1:2 shift error. I dont think its slipping. Just doesnt seem to be on the right shifting track. I have it back on stock and it still does it. Cleared the codes and they come back. Could it be the valves sticking?
Old 12-13-2008, 01:03 PM
Did you find a solution to your problem..? i am having the same problem with mine
