4r100 transmission problems need help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-14-2014, 05:22 PM Thread Starter
Cummins_Killer's Avatar
Okay so excuse my ignorance beacuse i really dont knoe much about transmissions, but in the past month or so my o/d light has started flashing sometimes when reversing or in first gear. Today it started doing it and i noticed after shifting from reverse to drive it would slip a little then catch when taking off, if i just lightly reverse then drive it acts fine, but if im reversing up a hill or backing up a trailer the light then comes on and the slipping begins, also when reversing i noticed a hissing sound, im not sure if this could be coming from the transmission or just something normal.
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-Diamond Eye 4" Turbo Back Straight Pipe
-33" Nitto Trail Grapplers on 18" XD Diesel
-2.8" Leveling Kit
Cummins_Killer is offline
post #2 of 4 Old 04-14-2014, 05:42 PM
Quoted: 27 Post(s)
Make sure battery terminals are clean and no corrosion. If the batteries can't properly receive the voltage from alternator than it starts sending signals every where, including the speed sensors. Took it to a transmission shop and two speed sensors later it still had o/d flashing. Truck was reading 14 mph idling in park so o/d would flash. Cleaning terminals fixed it. May not be your problem but its free to try.
strokin-7.3 is offline
post #3 of 4 Old 04-14-2014, 05:52 PM Thread Starter
Terminals are clean, thanks though
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-2.8" Leveling Kit
post #4 of 4 Old 04-14-2014, 08:03 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
sounds like a possible slipping tq converter
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
