OD light flashing?? P0781 code - Ford Powerstroke Diesel Forum
Old 12-08-2008, 10:15 AM
the code says 1:2 shift error. Is there a fix or just get a new tranny.
Old 12-08-2008, 10:19 AM
I'm sure there is a fix. I'll bump ya so someone with some tranny knoledge will see this!
Old 12-08-2008, 10:31 AM
is it slipping, making noise or anything strange ? if it just posted a code, clear it and reset the memory, drive it for a while and see if it comes back.
Old 12-08-2008, 10:33 AM
Once you go black......
Send a message via MSN to CanadianDiesel
Just a question, may sound dumb to you guys, but how do you check a code and reset it? I'm aware of codes but do you guys have special equipment?
Thanks
Old 12-08-2008, 10:41 AM
the rpms has to get up there then it goes in gear.no stange noises. superchips tuner does the codes. i have cleared them and after a little driving they come back. it goes in gear just not as fast as usaul. i may just be used to performance mode. i have it on stock now
Old 12-17-2008, 03:09 PM
I had a 1:2 shift error a couple of years ago...unfortunately 2nd gear was completely ripped out and ended up needing a new trans. Your trans might be on its way out, how many miles are on it?
Old 12-17-2008, 03:10 PM
Send a message via AIM to jhaddox
Thanks
you can do it with an sct tuner, you can go to autozone, advanced, napa parts stores and they have code readers there, normally u can borrow one or just buy one
Old 12-27-2008, 12:25 PM
my overdrive light was flashing the other day I guess this is not good news??
Old 12-27-2008, 06:28 PM
Usually not, but hopefully its just a code and a real easy (cheap) fix
I"m not 100% positive but I don't the the flashing OD light is just for the trans.
Old 12-27-2008, 06:54 PM
C.P.A. Member
Send a message via AIM to Fireman5606
Ok I dont mean to sound stupid but have you checked the tranny fluid? That could cause the slow to change and go in gear issues. I know you probably have , but I just had the thought because I have a tendency to overlook the simple stuff when mine acts up
