Is my trans starting to go? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-09-2014, 07:30 PM Thread Starter
cletusjermal's Avatar
Quoted: 151 Post(s)
When i take off from a stop and give it more then about half throttle it feels like it is slipping. It is pretty jerky. Then when i get going past about 5-10 mph it is fine. All other times it works fine. The temp has gotten almost up to the yellow a few times when pulling my trailer. I have always pulled over when it started getting hot though and let it cool. I only have the stock gauge for temp though so I'm not sure how accurate that is. I have changed the fluid and filter at regular intervals since I have had it. Never done the flush, just what drains out of the pan. Upgrades are in the sig. It has about 175000 miles on it. It hasnt been corrected for the tires though so it is a little more then that. 315/75/16. Im not real knowledgeable with Trans just understand the basics of how they work. Should I start planning on a rebuild soon?
2002 F350 7.3 4x4 SRW CCLB. GTP38R w/WW2 D-66, PIS 175/80 injectors, Sam Wyse Stage 2 Trans, 6.0 cooler, Banks Intercooler, 4" Turbo back Exhaust, PHP tuned TS 6 position chip, CNC 4 Line feed, HPOP and HPX Lines. International bellowed up pipes. AFE Stage 2 Intake w/ Dry filter. Banks exhaust brake and smart lock. Hutch/Harpoon mod, 910 Valve springs, Billet intake plenums. Firestone airbags. Trailready full guard front bumper. PIAA Driving and Fog lights. Micky Thompson Wheels.
cletusjermal is offline
post #2 of 3 Old 04-09-2014, 08:15 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
the way you are servicing your trans is the way most shops recommend.
so your good there.
does it jerk when you take off? kind of sounds like you need to lube the slip joint on the rear driveline.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 3 Old 04-09-2014, 08:29 PM Thread Starter
Quoted: 151 Post(s)
If i take off and ease into the throttle it is fine. But if i get on the throttle a little bit from a stop it feels sluggish and jerky. I notice it most when i have the trailer and am stopped on an incline and get going.
Is this the slip joint you are talking about?
http://www.eurekaboy.com/f250/slipjoint.htm
