ZF6 Issue... grinding in 1st and 2nd once in gear low rpm - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-07-2014, 10:14 AM Thread Starter
So I think the syncros are fine because it gets into 1st(not low) and 2nd just fine but if i'm going really slow I can hear and feel some light grinding. Once I get into it (higher rpm) it goes away. Seems to be worse when turning as well but is not exclusive to turning. Any idea what my issue could be? Thanks for the help!
e3mand is offline
post #2 of 12 Old 04-07-2014, 10:20 AM
timmyboy76's Avatar
gear rollover...normal. You can change the ATF in it, it'll help
timmyboy76 is offline
The Following User Says Thank You to timmyboy76 For This Useful Post:
e3mand (04-07-2014)
post #3 of 12 Old 04-07-2014, 10:21 AM Thread Starter
Awesome, good to know that it is not a bigger issue. What would you suggest for fluid?
e3mand is offline
post #4 of 12 Old 04-07-2014, 10:24 AM
timmyboy76's Avatar
normal mercon V, changed every 50k. i did the Amsoil crap, and messed my tranny up, purdy good. Now its a concauction of fluids to "help"ur out....little bit of lucas tranny stuff, mercon V, some gear oil...i dont recommend what im running but its work'n for me...
99.5 x-cab 7.3l, 6spd, 161k miles.....
post #5 of 12 Old 04-07-2014, 10:25 AM
timmyboy76's Avatar
ive heard good things about about the purple "something' called syncromesh...but its expensive. Think mercon V is all thats needed.
post #6 of 12 Old 04-07-2014, 10:44 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Sound like your clutch is not fully disengaging. How many miles on the truck and is it the stock clutch?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #7 of 12 Old 04-07-2014, 10:49 AM Thread Starter
I've looked into gear rollover and that def sounds like it. I would think that if my clutch was not disengaging all the way it would not by exclusive to 1st and 2nd gear at low RPM which gear rollover would be. Thanks for the input though! I'm going to give changing the fluid a try because it probably needs it anyway. Although, it sounds like this gear rollover is something Im going to have to live with as a ZF6 owner.
e3mand is offline
post #8 of 12 Old 04-07-2014, 10:50 AM Thread Starter
Royal purple syncromax, I have heard a lot of good things about it but it is super pricey. As all royal purple products are.
e3mand is offline
post #9 of 12 Old 04-07-2014, 10:08 PM
schlutzer's Avatar
Quoted: 18 Post(s)
You could also try the TonyBia mix.
3/4 full synthetic ATF
1/4 0w40 full synthetic
1 bottle of you choice of manual transmission additive/quiet.
I ran it for about a year, completely silenced my gear rollover and it was scary loud.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #10 of 12 Old 04-08-2014, 05:26 AM Thread Starter
How did the trans fair after that year? lol
e3mand is offline
