Clutch return spring - Ford Powerstroke Diesel Forum
Old 11-30-2008, 07:43 PM
Has anyone experimented and pulled the return spring out from the clutch pedal? i guess my question is does the clutch master cylinder have enough pressure to push the pedal back without that spring?
i'm walkin with a limp over here because my left leg is stronger than the other
Old 11-30-2008, 08:10 PM
JTA JTA is offline
Send a message via MSN to JTA
I removed my spring after I installed a south bend clutch and it still works without any problems
Old 12-01-2008, 04:11 AM
is there a particular reason why you can pull that spring out with the south bend versus the stock clutch?
Old 12-01-2008, 04:10 PM
JTA JTA is offline
not that I could see
Old 12-01-2008, 05:34 PM
the clutch pedal will stick to the floor with the southbend when you have a load on the drive line..... I had to pull mine the first time I towed my trailer after I installed the southbend...
Old 05-27-2010, 06:27 PM
The bracket on the firewall that holds the return spring along with the pedal broke on me today and the spring and part of the bracket fell out. Do I have to fix it or will it be ok without the spring?
