There is quite a few videos here, so please bare with me. Hopefully someone here can help me out. I am wondering if this is a transmission issue or just an issue with the tuning on my TW chip. Any advice will be appreciated. All of these videos are posted in the order i filmed them, which makes a difference. I explain later in the post.
First video is in the "Economy" tune, with me accelerating like normal. It shifts nice and firm, and exactly how i think it should.
Second video is Economy, full throttle. I lost traction in first, and it hooked up as it shifted to 2nd, thats why the RPM's drop so much during the shift. Otherwise normal shifting.
3rd video is the Daily tune, normal acceleration. The 1-2 shift feels firm, but it shifts into 3rd gear almost immediately after shifting to 2nd. When it shifts into 4th, the TC locks up firm, but the actual gear shift is slow and sloppy. Watch it a few times and watch the tach. Its just slow goin into 4th, and i don't like it.
4th vid is Daily, full throttle. 4x4 is on for traction. It doesn't shift as firm as it does in Economy. SES light is from over boost, my boost fooler isn't set right.
5th is the Tow tune, normal acceleration. Shifts are firm and solid.
6th, Tow at WOT. Once again, nice and firm. Hm, much the way i prefer other things too...
7th is the smoke setting. First is normal accel, then WOT. Normal accel does the quick 2-3 shift thing too. WOT the 1-2 shift was bad, the rest were mediocre. Also, once the turbo kicks in there is very little smoke, is that normal on the smoke setting? I figured it'd still have some smoke.
8th is Extreme, normal accel. Does the wierd 2-3 shift thing again. Also, if i put my foot on the throttle, it will start to accelerate normally, but then at about 1800 or 2000 it takes off, accelerates faster, without me pushing the pedal any further. And the SES light is back on. Its on from when i over boosted in daily. It will only over boost in daily and extreme. The wierd part is that if i over boost, i can switch it to tow or smoke and the light goes out, but then when i put it back to any other setting it comes back on. I tried explaining all that on the video but my mind when blank when i started talking and i just ended up sounding like a moron.
9 and 10 are boosted launches. The shifts freakin suck.
