torque converter - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-24-2014, 06:35 PM Thread Starter
Quoted: 8 Post(s)
torque converter
I have a 2002 f350 ccsb 4x4 looking to rebuild my transmission, I plan on 400hp at most. What torque converter do you guys run or recommend. I already have the john wood valve body in a box waiting. I will be rebuilding it with ford clutch plates. I can't afford a bts right now, so im going to do it the hard way. I've done a few already, still holding at stock levels.
2002 f250 ccsb 4x4, 250/200's,5 inch mbrp,itp boost fooler,regulated return/race fuel system, s&b intake, billet 4r100, swamps idm, lifted 2 inches, leveled, 35inch nittos on 18" s468, mishimoto intercooler, hydra tuning, detroit locker rear, dynomat, not done.........
2006 f350 ccsb 6.0, sct tuner 3015 custom tunes, studded, deleted, exhaust
mastertech79 is offline
post #2 of 13 Old 03-24-2014, 07:13 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
pi stallion is a good converter.
I think revmax sells a good torque converter too, might wanna dos some searching on the two.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #3 of 13 Old 04-09-2014, 06:33 PM
corn binder's Avatar
Quoted: 2 Post(s)
If you are rebuilding the trans, add a clutch in the low /reverse drum, replace the upshift modulator with a .427 $30 and I use a different solenoid block, it allleviates the problems associated with 99-up torque converter engagement/ failures. Around $200. Those are excellent upgrades& with a billet converter is a large improvement over a stock tranny for little $$$
99 f250 4x4 7.3 php tunes,20's
01 4x4 cc srw 7.3 550hp BTS trans
02 excursion LMTD 4x4 7.3
95mustang gt,86 5.0,03 gt
allis chalmers 185-d
corn binder is offline
post #4 of 13 Old 04-09-2014, 07:04 PM
MSTR-P's Avatar
Was thinking about a precision converter for mine.
'03 7.3 - Stock!
MSTR-P is offline
post #5 of 13 Old 04-10-2014, 10:55 AM Thread Starter
Quoted: 8 Post(s)
hey, can I use the modulator valve with the john wood valve body? Also, where did you get the solenoid valve assembly? Is it modified?
post #6 of 13 Old 04-10-2014, 12:33 PM
Quoted: 289 Post(s)
if you get a jw valve body he has already modified everything.
dont mess with it just install it.
post #7 of 13 Old 09-12-2014, 04:16 AM
good post for sure..
one poster recommended to "use a different solenoid block, it alleviates the problems associated with 99-up torque converter engagement/ failures"
The original posted stated "he had john wood valve body in a box waiting"
another poster said,," if you use John Woods valve body just install it.. everything is included..
Is that to mean the upgraded solenoid block is a part of the valve body modified my JW and no need to change anything else short of clutches etc. ??
just asking as I am looking to get a JW VB for my 03 SD with 168K miles on stock 7.3L and no real issues, ie shifts ok, no noise etc to help the stock transmission go longer..
Right now low to no heavy towing, but that might change in 2-3 yrs when we get ready to go full time RVing.
carl2591 is offline
post #8 of 13 Old 09-12-2014, 09:53 AM
layson's Avatar
Quoted: 84 Post(s)
call up and get one from John if you can. I wouldn't run a pi converter... They have been having some issues here lately. My last one lasted 40 miles.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #9 of 13 Old 09-12-2014, 11:20 AM
so what is a PI converter.
carl2591 is offline
post #10 of 13 Old 09-15-2014, 05:25 AM
Solid98's Avatar
Quoted: 9 Post(s)
Stallion Torque Converters | Precision Industries
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
