trans is shifting funny! - Ford Powerstroke Diesel Forum
Old 11-24-2008, 09:19 AM
I have a 2000 f-250 after Takeing off from a stop it shifts all gears good then it shifts in and out of overdrive about four times then it stays in overdrive untill you stop and take off again.
Old 11-24-2008, 09:20 AM
psd
valve is sticking need valve body work.
Old 11-24-2008, 09:28 AM
Is there some kind of fluid i can put in there to help?
Old 11-24-2008, 09:29 AM
Cynic
All that "trans magic" crap does is make your trans magically disappear. I would take it to a professional.
Old 12-01-2008, 03:12 PM
Valve is sticking, huh. What if the computer is telling it to shift back and forth because of speed sensor, tach sensor, temp sensor??????? Get it checked with a scanner to see what it's being told to do.
A big 10-4 to what Dirk said. Ablsolutly NOTHING but trans fluid. With 1 exception, Lubeguard. Not Lucas, (their eng oil products are good), not transmedic, not barstrans or any others that I have missed.
