4r100 leaking from vent - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-15-2014, 01:59 PM Thread Starter
So all of a sudden it just starts leaking fluid in reverse, slowly got worse over a week and now when reverse it pours out. It leaks out from the vent or around the vent on the back. The hose is disconnected, don't know if the pressure caused it to pop off? When in park it is only a small stream but reverse really pours. Any ideas?
powersmok is offline
post #2 of 7 Old 03-18-2014, 05:20 PM Thread Starter
post #3 of 7 Old 03-18-2014, 06:15 PM
aint no f ing hemi's Avatar
Someone can probably tell me why I'm wrong for thinking this, but have you checked your trans cooler? If it's still original, it might be clogged. When I replaced mine there was all kinds of gunk in it. I have no idea if that would actually cause your problem, but it's a place to start.
1999.5 f250 auto 4x4 cc long bed
diy intake
ccv mod
18k mod
zoodad mod
aint no f ing hemi is offline
post #4 of 7 Old 03-18-2014, 06:16 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I bet your transmission is cracked right there.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 7 Old 03-19-2014, 03:24 AM
looking4psd's Avatar
Quoted: 9 Post(s)
This is exactly what happened to me. I had a leak that was terrible in reverse, pulled the trans down to find I had cracks that the PO had tried to hide with some JB weld. The most frustrating part about mine is it drove fantastic, just would spew like hell in reverse.
Save your self some time, I know this sounds crazy, but if you aren't 100% sure it's coming from the vent pull the trans down and use some penetrant and developer to check for cracks. It's a lot of work to pull it down, but it's much more relieving to know for sure.
David
looking4psd is offline
post #6 of 7 Old 03-19-2014, 09:01 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Yup I just sold my old auto to a guy that described his leak exactly the way the OP has sadly
post #7 of 7 Old 04-28-2014, 11:46 AM Thread Starter
So found the problem, as i thought cracked case geting it built by a local trans shop. Hope this is the last time!
