Shoud I be concerned??? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-10-2008, 09:47 PM Thread Starter
agoodhi's Avatar
Exclamation Shoud I be concerned???
Hey Guys...
I had the truck loaded up with about 16 bales of hay/alfalfa and tried climbing a steep residential road in 2nd. I approached the hill very slow (no momentum) when I noticed the truck was not moving forward even though the rpms was up to 2k. I don't think the rear wheels were breaking lose, so I down shifted to 1st, and the truck crawled up the hill.
As a test, I went back (unloaded) and purposely stopped on the same hill with the truck in 2nd. I gave it some gas, and the truck didn't move forward, but when I downshifted to 1st, it crawled right up.
Usually, I have some momentum going up the hill and don't notice any problems, even in D.
Any thoughts? Is this normal (never owned an automatic before)?
--Ryan
2001 7.3 CC LB 4x4 Auto - AIS intake | ISSPRO EV - pyro, boost, trans | Tru-Cool | HD Torque Conv | RedHead Box | Powerslot/Hawk brakes | Bilsteins | Line-X | MagnaFlow muffler
CA SMOG test due in 2013
agoodhi is offline
post #2 of 11 Old 11-10-2008, 10:13 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
I dont think so.
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #3 of 11 Old 11-10-2008, 11:15 PM
regor's Avatar
Sounds like the clutches for second gear are worn out, i think you are going to need a rebuild.
Roger
2006 F250 Superduty 6.0L 6 speed manual
MODS
Banks with PDA, Iron Horse Bumper,Upfitter switches, High Idol Mod, Zoodad, Tint, K/C Lights, 08 F250 Rims, Remote start and Viper Alarm, 03 Turbo, Electric exhaust cutout, ARP Studs and EGR Delete Thanks To Scott @ Trucks Unlimited
Coming Attractions
SCT Custom Tuning
regor is offline
post #4 of 11 Old 11-10-2008, 11:37 PM
orng1's Avatar
Quoted: 3 Post(s)
Yeah sounds like a rebuild is in your future.
Bob
2001 F250 SRW Reg cab, long bed, 80k miles.
Now with DP tuner, Airaid intake and 4" Magnaflow turbo back exhaust.
orng1 is offline
post #5 of 11 Old 11-11-2008, 07:57 AM Thread Starter
agoodhi's Avatar
Just another bit of information... I purchased the truck with 135k miles and the PO mentioned the tranny has been rebuilt twice (not sure about the details of the work done). The second time he took it in, the shop also put in a heavy duty torque converter.
--Ryan
agoodhi is offline
post #6 of 11 Old 11-23-2008, 06:53 PM
Just put it in D and try to pull the hill. 2nd may be too tall a gear for the hill.
ipz2222 is offline
post #7 of 11 Old 11-23-2008, 11:05 PM Thread Starter
agoodhi's Avatar
That's what I was thinking too. I'll have to try stopping on the hill in D, and see if I could make it up.
I seem to remember my Jeep with 4.56 gears in 2nd gear wanting to die if I went too slow.
--ryan
agoodhi is offline
post #8 of 11 Old 12-11-2008, 02:30 PM
You shouldn't be in 2nd loaded down like that, it is very hard on the trans, it will overheat quickly. Either shift it manually starting in 1st, or leave it in drive and let the pcm do it for you.
Toptech is offline
post #9 of 11 Old 12-11-2008, 04:04 PM
what he said. remember, when you shift into 2 with an auto it stays in 2, even if you come to a complete stop it will start in 2nd gear. if you floored it and only got 2k rpm, then that is the stall rpm of the torque converter. if the 2nd clutches were slipping it would wind higher rpm than that. you just had too much load/too steep a grade for a 2nd gear takeoff.
2000 F350 SRW EC LB 4X4 OFFROAD
WASTEGATE DISCONNECTED
EBPV EXHAUST BRAKE MOD
MANUAL TC LOCKUP SWITCH MOD
MAX COOL 40K TRANS COOLER IN SERIES W/ V10 COOLER
TRIPLE PILLAR GUAGES(EGT,TRANS,BOOST)
WICKED WHEEL
PHP 6 POS CHIP (1:STOCK, 2:45 TOW, 3:60 TOW, 4:80 PERF, 5:HIGH IDLE, 6:NO START)
DIY TYMAR INTAKE
MUFFLER DELETE
thomasinnv is offline
post #10 of 11 Old 12-17-2008, 07:09 PM
What he said!! Let the PCM do it's job.
tbolt is offline
