Tranny problem Emergency - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-08-2008, 07:37 AM Thread Starter
Unhappy Tranny problem Emergency
My 2001 powerstroke has shifting prblems. I will pull out in 1st and it will not shift into 2nd until i get to 20mph and i have to let off the petal then it shifts that is the only time i have problems with it, it shifts fine through all the other gears. The truck has 146,000 miles on it. Any info is appreciated Thanks For The Help. Also i took it to the tranny shop and they said its not the clutches and the fluid looks brand new and not burnt they are not for sure what it is and they said $400.00 just to pull it.
01fordpwr is offline
post #2 of 3 Old 11-09-2008, 07:04 AM
Brickhouse's Avatar
Looks like we have about the same condition going on.
http://www.powerstroke.org/forum/99-...e40d-help.html
01 F550 Eclipes "Thoroughbred" Super Hauler 2WD
6p FU2 chip, w/ Garrett & 4" Diamond Eye Turbo Back w/ dual 5" tips
JWVB, Adrenaline HPOP, Ford AIS + Fender Mod & RamAir Zoodad
CCV, AIH mods, EBPV Delete (PWR Elbow)
AE + gauges
S135 rear 4.88, Gearvenders OD
Centramatic Balancers, Kelderman airride
101K on the clock
Brickhouse is offline
post #3 of 3 Old 11-09-2008, 07:25 AM
97 golden stroker's Avatar
i have never been inside one your your trannys, but to me it sound like you have a valve sticking. could be a 1 2 shift valve but dont quote me on that. and if this is the case then they do not have to pull the tranny just the pan then the valve body.
97
afe intake
ats intercooler
3in. down pipe to 4in str8
fpr shim
terminator hpop
warm up valve delete
tw 6 position
southbend clutch
Stage ones from Rosewood diesel
SD IDM
d66
12000k hid dual element
thinking real hard about a nozzle upgrade
220k
97 golden stroker is offline
