Time for a tranny service - What exectly should i have done? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-24-2014, 10:05 AM Thread Starter
I recently purchased a 2002 F350 Lariat with 117000 miles. It's time for a tranny service and I'm wondering what exactly I should have done. Flush/No flush? Best fluid to use? Best place to take it to? Could I do it on my own? I'm pretty mechanically inclined. I just want to be sure it gets done right. Thanks in advance.
scottmccurdy is offline
post #2 of 10 Old 02-24-2014, 10:15 AM
hansel's Avatar
Quoted: 97 Post(s)
You can do it yourself it's not hard at all, I would drop the pan and replace the filter then flush the transmission, too flush the transmission you will need 5 gallons of fluid (Merc/Dex) I use the Gastrol fluid, then what you do is remove the return line and I use a 10ft piece of clear tubing that I plug into the return line. When you put the pan back on you will need to put in about 1.5 gallons, then start the truck and pump out 1 gallon, shut off the motor and replace 1 gallon, do this until you have cycled your 5 gallons. This will change the fluid in the transmission and converter.
Here is a detailed flush procedure by Mark a former Transmission Tech with Ford
http://powerstrokenation.com/forums/...ead.php?t=4338
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #3 of 10 Old 02-26-2014, 06:13 AM
Quoted: 2 Post(s)
I flushed my fluid after purchasing my truck 2 years ago. 272000 miles and the fluid was dark but the tranny was shifting ok. I was told by some to not change it because it would cause problems.
I felt it needed changing anyway. Dropped the pan and changed filter and also took the plug out of the torque converter and drained it. I have a 2000 and it has a very noisy converter and I was hoping to quiet it down. I also gently blew the fluid out of the cooler lines. Refilled it and it still shifts well. Still has a noisy TC though, didn't even touch the sound. Fluid looks better but still has a bit of a dark tint to it.
I'm planning on driving it til it fails or reasonably needs another fluid change.
tvengineer is offline
post #4 of 10 Old 03-12-2014, 11:56 AM Thread Starter
Thanks for the info
post #5 of 10 Old 03-12-2014, 12:04 PM
bigred_stroker's Avatar
I always recommend not flushing. When I had my 02' I was warned not to flush the trans because it will loosen up sediments and cause the whole trans to go bad quicker. Ended up doing the flush and a week later the transmission went out. Maybe it was coincidence however. My friends trans in his 99 never went out and he was always with the theory of change the filter and fluid only.
2011 F-250 6.7L FX4 Lariat CCSB Tuxedo Black, Black Leather, 6" Lift w/ 37" Nitto trail grapplers 20" XD rims.
bigred_stroker is offline
post #6 of 10 Old 03-12-2014, 12:07 PM
layson's Avatar
Quoted: 82 Post(s)
That is all I do, drop pan, change filter and then fill with fluid. Do it ever 30k or so...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #7 of 10 Old 03-12-2014, 06:10 PM
hansel's Avatar
Quoted: 97 Post(s)
Who warned you?? was it a transmission person?? I follow the procedure layed out by Mark who use too work for Ford's transmission dept.
I'm not expert but wouldn't you want too clean the sediment out??
I just want to do what's best for my over $4K transmission
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #8 of 10 Old 03-12-2014, 07:13 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
i think most guys just drop the pan and change the filter.
i THINK hucorey mentioned that bts recommends this as well.
hopefully they will chime in.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #9 of 10 Old 03-13-2014, 09:49 AM
Quoted: 2 Post(s)
I elected to try and see if I could improve fluid color and quiet the converter. I was told by a powerstroke mechanic my torque converter would soon fail because of the noise it was making. I figured that I had not so much to lose if it was on its way out. That was 20k miles ago since my flush. I am considering it again.
post #10 of 10 Old 03-13-2014, 02:33 PM
Quoted: 258 Post(s)
my friend has a 7.3 work truck that the converter has sounded like chit for the last 200k miles.
