Rear speed sensor ? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-04-2008, 02:55 PM Thread Starter
EVIL OVAL's Avatar
Rear speed sensor ?
I was just wondering if anyone had a picture of the rear speed sensor on the tranny...my OD light was flashing so i had it checked for codes and the rear speed sensor was the only one that showed up.
2000 ford F-350 CC PSD, 6 inch pro comp lift, Moto Metal 957's, 37 13.50 toyo mud terrains,Afe stage 1 air intake, 4 inch straight pipe.
EVIL OVAL is offline
post #2 of 10 Old 11-04-2008, 04:02 PM
ricksstang's Avatar
Speed Sensor
Pretty sure that the speed sensor is located on top of the rear diff. Same one for the anti lock brakes.
Rick
Dirty South Strokers
95 Crew Cab Dually PSD
3"dp into 4"exhaust
Gauges: Boost, Trans Temp, EGT
K&N Intake
Performance built Trans
Edge EZ
ricksstang is offline
post #3 of 10 Old 11-04-2008, 05:06 PM Thread Starter
EVIL OVAL's Avatar
so is there a different name for the sensor on the back of the trannie? I just replaced my sensor on the rear diff because my ABS light was staying on...I had it scanned today and it showed the sensor on the back of the trans...i thought it was called the rear speed sensor but maybe its called something else?
post #4 of 10 Old 11-05-2008, 02:55 PM
did that fix the problems cause i got the same ones
2001 F-250 4x4
Marty's Fuel
Swamp's 250/200's
Swamp's Tunes
PDR Super GTP Turbo
BTS
PMR'S
Soon to come - SRP 1.1
njjeep is offline
post #5 of 10 Old 11-05-2008, 03:08 PM
symbols's Avatar
The only one I know of is the one on the rear diff.
Jason
"Using a thug's murderous rampage to call for gun control is like using Barack's reckless spending to call for higher taxes."
--Michael Berry, American philosophizer & Talk Radio Czar, 1970-?
symbols is offline
post #6 of 10 Old 11-05-2008, 03:50 PM Thread Starter
EVIL OVAL's Avatar
I have'nt got around to putting it in yet going to do that tonight...Ill keep ya posted.
post #7 of 10 Old 11-05-2008, 04:02 PM
ssdzl's Avatar
sensor on rear diff definatly get you your speed mine had a small miss hap and had to fix it and my speedo was rele wacky and i do belive my o/d light was flashing. is the trans shifiting werid???? was there any cause for you to expect a tranny issue ?
late 1999
BTS Trans
coming soon to a track near you 12v ford drag truck with p-pump built by Scheid
ssdzl is offline
post #8 of 10 Old 11-05-2008, 04:23 PM
International Threat
Marty's Avatar
Depending upon the year, there could be 2 in the trans. There is a plug that you just push the tabs away on and there is a 3/8ths bolt holding the bracket in and then you just need to pry the sensor out.
There is one on the tailshaft just before where it necks down, and another on the driverside just after the bellhousing.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #9 of 10 Old 11-05-2008, 06:34 PM Thread Starter
EVIL OVAL's Avatar
the only issue i had was the OD light would flash and sometimes if i had just started it up it would act like when a trans is low on transmission fluid and wouldnt really move...it only did this to me 2 times, the transmission fluid was fine both times when i checked it. The only other thing is my OD light would flash but it shifted fine, so i had a guy where i work pull the codes with a solstis, not sure if that is the correct name but its a snap on brand and the sensor is what showed up. I replaced the sensor tonight so i guess its kinda to early to tell if that was the problem as it hasnt thrown any codes as of yet.
post #10 of 10 Old 11-23-2008, 03:26 PM Thread Starter
EVIL OVAL's Avatar
Well heres a update...i dont think it was the sensor, Yesterday it threw a code again but when i started to go it acted like it came out of gear for a second and then took off, TC maybe?? Going to have it scanned again 2 morrow, The funny thing is it only does it when the truck is cold and not up to temp yet.
