The trucks surges in reverse - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-12-2014, 01:59 PM Thread Starter
1982atm's Avatar
when iI put the truck in reverse it surges ... like when i hit the gas pedal it goes then cuts out then goes the cuts out ... anyone ever experienced this ??? no other problems
1982atm is offline
post #2 of 8 Old 01-15-2014, 06:34 AM Thread Starter
1982atm's Avatar
anyone BUMP
1982atm is offline
post #3 of 8 Old 01-23-2014, 12:55 PM Thread Starter
1982atm's Avatar
well i guess no one else has had this prob
1982atm is offline
post #4 of 8 Old 08-18-2014, 09:35 AM Thread Starter
1982atm's Avatar
bump TTT!!!!!!!!!!!!
1982atm is offline
post #5 of 8 Old 08-18-2014, 09:36 AM Thread Starter
1982atm's Avatar
when it does this the OD light is flashing on the shifter handle
1982atm is offline
post #6 of 8 Old 08-30-2014, 09:45 AM
You got a code then. You're gonna have to get it scanned.
Sntgard is offline
post #7 of 8 Old 08-30-2014, 01:34 PM
Vannnce's Avatar
Quoted: 13 Post(s)
x2 on getting it scanned. Mine started surging in reverse like that, than started doing it in first. Thought my brakes were sticking. Than my torque converted became the obvious culprit, wasnt unlocking/ locking correct. than my transmission went bang
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #8 of 8 Old 01-03-2015, 12:36 PM Thread Starter
1982atm's Avatar
Park Neutral switch solved my prob FYI
1982atm is offline
