OD light blinking?
The other day i was pullin a load and i put it to the floor(traffic was nuts) and then when i let out the OD light started to blink? the trans didn't seem to act any diff though? well on the way home pullin the same load i looked down and the light was blinkin again but i don't remember ever getting on it really. the first time it happend when i got to my destination i shut the truck off and it didn't come back on when i drove home with out the load. when i came to pick up the trailer next day is when it came back on? i have a bullydog flip chip exhaust and intake.. it only did this when it had the load behind it. truck seems to shift as normal though.
There's something wrong with the transmission system. It might be inside the trans or one of the sensors outside, or even a wiring issue. The only way to know is to find someone with a Ford specific scan tool to read the code that was stored. The auto parts places that read codes free can't read a Ford trans code.
fill out your sig so we know what your driving (helps)
don't let anyone clear the code till your dealer/mechanic checks it out |
well i used a sct to pull the codes now i got to look them up whats the web site were you can look them up? i found it once can't remember now
well pulled the code .....over heat on trans!!!!!not good what should i do???
fill out your sig so we know what you have.. if you have a 7.3 upgrade to the 6.0 trans cooler a bigger trans pan always help too let us know what you have so we can help you
A 6.0L cooler will help a lot, a bigger pan will only help empty your wallet.
i just need to find a 6.0 cooler and switch to synthetic... im about to fill out my sig.
