OD flash,ABS,speedo - Ford Powerstroke Diesel Forum
Old 09-26-2008, 07:19 PM
OD flash,ABS,speedo
I have had a problem with the OD light flashing speedo not working until 40mph and abs light. I have been reading threads on the subject. They all have ended badly and nobody can figure out. Well I replaced my VSS in the rear end and have not had any of these problems yet. Thoughy I would share.
Old 09-26-2008, 07:26 PM
duct tape & zip ties
When the speedo is not working, when the OD light is flashing and when the ABS light is on. The VSS ( Variable Speed Sensor) on the rear diff is usually the cause.
