trans wont shift unless I let off throttle - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-02-2014, 08:10 AM Thread Starter
hello last night drifting my 2000 f250 7,3 truck shifted fine then heading home from a dead stop accelerating it wont up shift no matter how high off rpm i hit unless you let off the throttle while moving then it will and it does this in every shift.
also noticed the overdrive light on my shifter blinking
any ideas?
silver_bullet7.3 is offline
post #2 of 5 Old 01-02-2014, 08:15 AM Thread Starter
BTW fluid level is fine, color was dark,
truck has 180,000 ts programmer that dosnt like staying plugged in and van turbo with ww2
is it a electric harness or old school vacuum line or what
post #3 of 5 Old 01-02-2014, 08:21 AM Thread Starter
also i have a torque convertor lock switch, i was wide open for a while not sure if tc is bad or if snow and cold temps screwed with wiring or what??
post #4 of 5 Old 01-04-2014, 05:58 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
possibly issue due to your chip coming off/being loose.
use duck tape to hold the chip on lol
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 5 Old 04-26-2014, 11:00 AM
tompa00's Avatar
I had a similar issue. trans getting hot. od light blinking. then I got home to back in the driveway and wouldn't shift into reverse. then after a bit I magically had reverse. I also have a ts chip. ill be sure to check and see if its loose. I drove three hours last night to Missouri with no issues. the next day is when it started acting up.
2016 F350
Sota Novakane 20x10 -19mm
Bilstien Leveling Kit
AMP Research Steps
more to come....
tompa00 is offline
