99 7.3 no overdrive and reverse slips - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-30-2013, 03:02 PM Thread Starter
Ok buddy just got a truck no overdrive, and reverse takes 5 seconds or so to engage. And reverse slips. No overdrive light flashing or anything. Goin down the road if you let off the gas it drops right down to idle, shouldn't the rpms stay up and then drop to idle after you hit the brake? Thanx in advanced
born2ride14 is offline
post #2 of 4 Old 01-01-2014, 05:43 AM
Quoted: 861 Post(s)
Feedback Score: 3 reviews
Reverse taking a few seconds is normal all the 7.3s do it.
Its supposed to pretty much drop to idle. Not immediately but within a second or two.
I bet this is his and your first exp driving a 7.3. All you describe is fairly common.
Corey@CNCFAB is offline
post #3 of 4 Old 01-01-2014, 05:44 AM
Quoted: 861 Post(s)
I bet this is his and your first exp driving a 7.3. All you describe is fairly common. Its not a gasser. Much different driving characteristics.
post #4 of 4 Old 01-01-2014, 05:51 PM Thread Starter
I've owned 3 obs powerstrokes with the e4od any ways I'm pretty sure reverse shouldn't slip and there should be overdrive
