2000 f250 od light flashing - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-29-2013, 02:29 PM Thread Starter
Recently purchased my first diesel. Thank you all for the information here that made the decision easy to go with the 7.3.
2000 f250 7.3 with 4r100 tranny and 4x4
made it home with the truck but noticed in route that the shifting seamed a bit harsh and the od light was flashing. The transmission was just rebuilt 4 months before i got the truck. here is a list of all done thus far
Codes
p1754 CCS(Coast Clutch Solenoid) circuit fault
p0470 Exhaust Pressure Sensor Fault
Ordered parts for the pressure sensor(tube was rusted thru) but havent recieved yet.
checked all electrical connections to tranny and visually inspected the wiring.
while driving had my solus pro connected and watched the CCS in the data field and it always shows that its off, regardless of speed and gear its always off
Also to note the od light will start to blink within 30 seconds of starting the truck while still parked. If i switch the od to off the light never blinks, but when i switch it back on within the 30 sec it starts flashing again.
Here is my question now that the background is out of the way.
Does anybody have a schematic of the transmission wiring, hopefully including a pinout on the connectors and the proper voltages along with the resistances of the different solenoids?
Thanks in advanced
Nathan
boltcustoms is offline
post #2 of 2 Old 01-03-2014, 04:42 AM Thread Starter
Just wanted to post this so it's available if any body else has this issue. The CCS ground is pin 5 and the supply power is pin 1(pasanger side connector that comes out of tranny) The resistance across the two should be in the range of 20 to 30 ohms. Mine read as an open circuit so I've ordered a new solenoid pack. Will post back once installed to let everybody know if it was my only problem.
