Flexplate Upgrade? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-27-2013, 10:25 AM Thread Starter
Unhappy Flexplate Upgrade?
2000 Excursion Limited 7.3 (235hp) 4x4 4E0D w/ 203,xxx. Just swaped engine w/ 2001 (275hp) from an F350. Original flexplate was cracked at the bolts so replaced with non OEM flexplate from Autozone (it was Sunday and had no other immediate source) for the original engine 3 weeks ago. It is now making the same rattling noise the original broken plate was. My question - Is the flexplate for the 2001 (275hp) a stronger plate to accomodate the extra hp? I probably should have gone with OEM unless someone has a better recomondation.
KOKOPELLI is offline
post #2 of 6 Old 01-01-2014, 07:24 PM
If you are interested in an oem flex plate I have one.
Matthews is offline
post #3 of 6 Old 01-03-2014, 06:45 AM Thread Starter
Thanks for the reply and if I hadn't already replaced the flex plate I would be interested. Though it's still aftermarket I am crossing my fingers with a plate from a different company.
post #4 of 6 Old 01-03-2014, 07:52 AM
broncomitch's Avatar
Sure it's not a balancer issue?
And I'm guessing you torqued the bolts with thread locker?
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #5 of 6 Old 01-03-2014, 07:56 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Are you sure it's not the converter making the rattle noise? There were some issues with those converters.
dhanna6powerstroke is offline
post #6 of 6 Old 01-03-2014, 12:01 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
the flex plates were the same, the 275hp engine wasnt any more powerful.
its just rated higher for a manual.
post a video of the sound, your describing a bad torque converter.
and you dont have a E4OD transmission you have a 4r100.
since your truck is a 2000 you can probably drain the torque converter and see what comes out.
pull the inspection cover off, and turn the flexplate until you see the drain plug for the tq converter
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
Tags
flex plate , flexplate
