Shifter Cable - Ford Powerstroke Diesel Forum
post #1 of 1 Old 12-14-2013, 04:53 PM Thread Starter
Shifter Cable
2001 4r100
I just finished replacing the busted shifter tube along with the shaft and bushings and all that. Anyways, before the tube broke i could move the shift lever from park to first no problem. Now with it all back together i can only go from park to drive. Somehow i can't move the shift lever into second or first.
I don't want to dick with the cable if i don't have to but i'm not sure if i should be looking at the cable or did i mess up on the tube/shaft install?
Greenman01 is offline
