hot tranny need help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-04-2013, 01:34 PM Thread Starter
Hey guys i was driving my 02 around today and didnt go very far and noticed the transmition gauge was running way higher then normal. what could this mean and what should i do?
powerbrody is offline
post #2 of 4 Old 12-17-2013, 06:18 PM
Bypass valve stuck open?
Do you have an aftermarket trans cooler?
2001 F-250 XLT
6637 air filter, zoodad w/ custom enclosure, 4" TB straight pipe w/ 5" tip, water injection, PHP hydra-chip, boost, EGT & trans temp gauges, Sonnax valve tricumulator kit, AIH delete, foil delete, external IC/TC water mist spray
Troponin is offline
post #3 of 4 Old 12-17-2013, 11:24 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
the stock trans temp gauges arent that good anyway.
does it give you a actual temp reading?
stock cooler sucks, bypass valve issue.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #4 of 4 Old 12-18-2013, 01:12 AM
Quoted: 908 Post(s)
Feedback Score: 3 reviews
Bypass valve won't mean much. As BTS removes it anyway. Unless urs is stuck closed and something is keeping from not opening all the way. Like a sticky T-stat.
Corey@CNCFAB is offline
