guru's on clutches 97's - Ford Powerstroke Diesel Forum
Old 08-27-2008, 07:43 AM
The ole truck is getting hard to get in gear ,mainly lower and reverse, I checked the clutch and it looked fine,it's been replaced once in 233000 miles.so I looked at the pedal rod connecting to the clutch rod and it has about 1/2" play in it could that be the problem or the slave cylinders
Old 08-27-2008, 11:58 AM
no clutch guys here today?
Old 08-27-2008, 06:48 PM
yes the bushings wear out.
i replaced mine with a kit i got off e-bay that used a Heim joint, nice little set up and much smoother action.
Old 08-28-2008, 09:21 AM
Also check the fire wall for flex while pumping the clutch. If it is flexing go to the dealer and get a reinforcement bracket.
Peter
