TQ converter - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-24-2008, 08:55 AM Thread Starter
Shaking the Bush Boss
CHUCK's Avatar
TQ converter
Tell me about TQ conveters....whats the advantages of using a triple disc converter?
Chuck
CHUCK is offline
post #2 of 12 Old 08-24-2008, 09:13 AM
Other vehicle is an F250
Hank's Avatar
Hey Chuck:
I found this on another site. Thot it might help. At least get some conversation started. I am curious too. I have actually heard some say tha a stock FORD tranny used a triple disc.
i have a Goerend tripple disc, it locks up hard but not too hard really. i don't think that the problem is the amount of clutches a converter has because when all these different brands and makes of converters lock they are in direct drive. the multiple clutches keep it from slipping. i believe it is how loose the converter is when in fluid coupling. my converter is really tight so when it locks there is maybe a 200-300 rpm drop from unlocked to locked. when i had my stock converter it would loose 600-700rpm when it locked up.....
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #3 of 12 Old 08-24-2008, 10:53 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Be careful of getting a big TQ like a Stallion..they will kill a stock trans. A great TQ to use is a 6.0 TQ setup for your trans.
CT Performance, Inc. is offline
post #4 of 12 Old 08-24-2008, 06:09 PM Thread Starter
CHUCK's Avatar
anyone else?
Chuck
CHUCK is offline
post #5 of 12 Old 08-24-2008, 06:13 PM
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
You can use a 6.0 TC on a 4r100?
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #6 of 12 Old 08-25-2008, 08:21 AM
Quoted: 3 Post(s)
Yes..not a stock one but one set up for a 4r100
You should also replace the pump with a modded one or mod it for flow and replace the bushing.
Replaceing the VB or modding it is a must do also for the best performance.
Cary
post #7 of 12 Old 08-25-2008, 05:21 PM
If a sigle clutch converter will hold 400 ft lbs of torque, what will a 3 clutch converter hold??? Begin to see the advantage??
Ford never had a 3 clutch converter, only a 2 clutch and it was junk. The metal slots that held the steel plats were too soft and it would beat itself to pieces.
You can not use a 6.0 converter in a 7.3 but,,, you can get a 7.3 converter with a 6.0 bowl on it. It makes for about 200 less rpm on the stall, or lower eng speed on acceleration
ipz2222 is offline
post #8 of 12 Old 08-25-2008, 05:27 PM
Raul@Stealth Automotive's Avatar
i seriously doubt a stock single or 2 disc torque converter will hold 400hp.... my guess is they start slipping at around 320hp (to the wheels)
the main you want to upgrade to a tripple disc is so that you eliminate slippage... slippage causes heat.. and heat is the number 1 killer of your trans...
with proper tuning a triple disc TC is a great upgrade...
Raul@Stealth Automotive is offline
post #9 of 12 Old 08-26-2008, 10:00 AM
Quoted: 3 Post(s)
Hate to tell you but as John Wood just told me today all Ford tranies have had triple disks since '96. FYI all TQ's that JW uses are based on the 6.0 TQ...not a 7.3 with a 6.0 bowl.
Cary
post #10 of 12 Old 02-23-2009, 08:08 AM
soutthpaw's Avatar
Raul, you didn't read carefully he said 400ft lb of torque not 400HP
DJ
ASE Master Auto Technician.
2001 Excursion 4x4 7.3, 4" lift & exhaust, Transgo, Issopro gauges. 200A DB alternator.
PHP Phoenix w/ Minotaur tuning pkg.
2000 International 4700 T444E
Project Truck
soutthpaw is offline
