Shudder in OD only - Ford Powerstroke Diesel Forum
post #1 of 17 Old 08-22-2008, 07:13 PM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Shudder in OD only
I am having a shudder in OD only going down the road. I checked the carrier bearing, and its good. I have heard of TC shudder. Is this what I am experiencing? It starts to shudder in the gear before OD, then it shifts and it really shudders esp in low RPMs. If I mash it and it shifts into passing gear, the shudder immediatly goes away. Any ideas?
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 17 Old 08-23-2008, 06:33 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Bump anyone?
Nick
"The Mistress"
post #3 of 17 Old 08-23-2008, 06:46 PM
Homeslice's Avatar
sometimes even if you wiggle your u joints and they don't have play they may still be worn out and need to be changed.
Homeslice is offline
post #4 of 17 Old 11-13-2008, 10:12 AM
Motown Fire's Avatar
Did you ever find what your problem was ???
Delmar Expedited Transport
Oil Field Freight & Hot Shot Services
Motown Fire is offline
post #5 of 17 Old 11-13-2008, 02:51 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Yep. It turned out to be a couple of injectors missing. When you put it under load, lugging it, it makes a shudder. Doesnt do it in the higher rpms cause its not lugging so much.
Nick
"The Mistress"
post #6 of 17 Old 11-14-2008, 11:20 AM
Were the injectors bad and have to be replaced or was it a wiring issue ???
post #7 of 17 Old 11-14-2008, 11:28 AM
LHMissions's Avatar
Oddly enough I had the same problem with my 6.0 & I had 2 injectors that went bad and were collapsing at the lower rpm - when the trans went into OD.
I dont understand it - but replaced the 2 injectors and problem went away. That was 10,000 miles ago.
LHMissions is offline
post #8 of 17 Old 11-14-2008, 01:14 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
well, its been so busy I have not had tome to send them to casserly to get gone through. So i still have the problem as of now. I will be fixing it soon though. Things have started to slow down a bit
Nick
"The Mistress"
post #9 of 17 Old 03-23-2009, 11:48 AM
99PSD-White's Avatar
WOW I have the same problem! with mine shuttering
99PSD-White is offline
post #10 of 17 Old 03-23-2009, 01:55 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
yep. found one injector collapsing under load. causing shudder. if you do a buzz test and a cyl contribution test, you should be able to find it
Nick
"The Mistress"
