In overdrive - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-26-2013, 09:07 AM Thread Starter
t-ray-4ray's Avatar
Quoted: 89 Post(s)
In overdrive
Trans shifts great through all the gears pulls strong but when it gets to overdrive it shifts into overdrive then it's like the tourqe coverter unlocks and te engine jumps up about 200 rpms
Sent from AutoGuide.com App
2000 f-350 4x4 extended cab, went from a flatbed work truck to what you see now, all done by me. Early 99 engine, billet low stall converter, rebuilt trans, all new uvch, new belt tensioners and idler pulley, rebuilt injectors, all new icp, idm, cps, hutch mod, k&n intake, white valve covers, wicked wheel, 5 inch exhaust, php hydra chip 15pos, 8" superlift, 20 inch black and machined rims, 2" billet spacers, 37/13.50r20 toyo open country tires, rough country dual stabilizer, 05 front end with 10k hid lights, amber led cab lights, 09 ford van bucket seats, 2010 f150 center console, b&m ratchet shifter, aero force scan gauge, b&m trans cooler used as a fuel cooler,
t-ray-4ray is offline
post #2 of 3 Old 11-26-2013, 09:08 AM Thread Starter
t-ray-4ray's Avatar
Quoted: 89 Post(s)
I am going to change the filter and fluid tonight it's a 99 350 2wd dually with 148xxx miles
post #3 of 3 Old 11-27-2013, 04:55 PM Thread Starter
t-ray-4ray's Avatar
Quoted: 89 Post(s)
Changed the filter and fluid still same thing I am leaning towards the PCM now after research and my cruise control stopped working I wonder if they are linked in some way cause it just started doing this. Friday I am going to check with the local ford dealer to update my PCM
