4R100 won't stay in parků. help! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-21-2013, 05:06 PM Thread Starter
HunterER7's Avatar
well my 02 f250 won't always go into park. sometimes it does and sometimes it doesn't. also with this problem comes the starting situation. the truck wont start every now and then in Park. sometimes it will, sometimes it won't. when it doesn't i shift into neutral and it starts right up.
any suggestions here as to whats going on?
thanks, earl.
7.3 Crew Cab Long bed.
Stage 2 AFE intake, 4" MRBP turbo back, Stage 2 Full Force injectors, Adrenaline HPOP, Driven diesel Regulated return fuel system, Custom tuned TS 6 position chip, Edge evolution CTS gauge, Built Trans
Estimated. 380-450 hp
HunterER7 is offline
post #2 of 6 Old 11-21-2013, 05:34 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Do you have allot of play in the shifter handle? There's two torx bits under the dash that tighten the handle to the shift mechanism. If it gets loose, then it won't shift in the right gears
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 6 Old 11-21-2013, 06:43 PM Thread Starter
HunterER7's Avatar
I actually did that right before you replied. It did seem to fix the problem at the moment. I'll have to see within the next couple days if it's still doing it or not.
Thanks a lot dude!
post #4 of 6 Old 11-21-2013, 07:05 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
mine does this.
the Previous owners wife put the truck into gear without pushing the break in one day
so the collars broken inside. hope this isnt your issue.
if you still have issues the collar needs to be replaced.
mine wont start occasionally so i have to push up on the handle then it starts
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 6 Old 11-22-2013, 05:01 AM Thread Starter
HunterER7's Avatar
Originally Posted by blue99stroker View Post
mine does this.
That's rough! Mine was just loose tightened it up and it seems to be good now. So we'll see
post #6 of 6 Old 11-23-2013, 07:03 AM
Quoted: 270 Post(s)
good luck
