Clutch Slipping... - Ford Powerstroke Diesel Forum
Old 08-16-2008, 06:33 PM
Clutch Slipping...
Last night i was driving it, and it was fine (to me) stiff to push in and it releases right off the floor. So this morning, i left for work and i pushed the clutch in and its soft, goes in gear fine, but to release it i had to let it all the way out.. it was strang, but i was still half asleep... when i got off work heading home, it was doing the same thing, so i punched it and as soon as it hit boost it just tached out slipping real bad. I don't know anything about these clutch systems. any thought on what it could be, other then a new clutch? yesterday was fine, i don't understand over night it changed. My truck is a 99 F-350 6 speed with stock gears and 37's. just has a intake and exhaust. If it is the clutch, whats the best low budget set up. I am only 18 and don't have much money at all..
thanks for any help!!
Old 08-18-2008, 07:39 PM
no one has had this problem?? where is a goo place to get a cheap clutch from??
Old 08-18-2008, 07:51 PM
clutch is gone .. or pressure plate is screwed
I guess if you cant spend the $$ on a good southbend (i recommend it though do it once and then not have to worry anymore) then Id say grab a Valeo I just put one in my wrecker with the single mass conversion and it works great .. I work the hell out of the wreckers too
Valeo Clutches | Valeo Clutch
Old 08-18-2008, 07:53 PM
is the single mass flywheel the way to go?? how much did you kit cost/ what was the part number?
Old 08-18-2008, 07:57 PM
you have a superduty it is single mass already thats what ya wanna stay with ...
the valeo one i installed was a 1997 so it had dual mass flywheel.. I used their conversion kit
heres the one for your truck
53302001
Old 08-18-2008, 08:05 PM
sorry i don't know much in this area... I have been looking into the south bend one, its $650, or this one you are telling me around is around $500 on ebay...
Old 08-19-2008, 07:46 AM
go with the southbend if ya can swing the extra $$$
Old 08-20-2008, 06:59 PM
I went ahead and bought the south bend setup rated at 350HP... i think that will be a good set up for a driver.. are there anything special about installing these??
thanks
Old 08-20-2008, 07:01 PM
nope same as a stock clutch install
Old 09-02-2008, 07:48 PM
The South bend clutch is great!! the pedel is super easy, the only thing different is its grabby, so thats going to take some getting use to... since i went with a high power clutch and i don't have any real mods yet, when i put a chip in it and stuff, is it going to be different??
