Tranny and TC questions?
Ive got a 99 7.3 with the 4r100. This tranny is a 4 speed correct? (including overdrive) my question is i feel 4 "shifts" so can anyone help me out as to when i should feel my torque converter lock up? My tranny is a little built up but i want to get a BTS. I would just like to know a little more about mine for now. Also, when i do 4wd launches the tranny will like go in and out then back into 3rd but be at like 1100-1200 rpms, but im not sure if that is the torque converter not sure to lock or not? the OD light does flash but once i shut the truck off and restart it the tranny shifts smooth again. Sorry for the long post but i just can't seem to understand this transmission yet
thanks guys
I feel my TC lock up. Does feel and look (tach) like another gear.
Where abouts in the mph frame do you feel this? i know it might be a little different because you have 35s. Driving normally does it lock right before over drive or after shifting second?
Factory locks TC between 3rd and 4th. Feels just like a gear shift.
so it locks before overdrive? overdrive is technically 4th gear right? thanks for the quick responses guys
Yes sir. Lockup before OD.
Thanks Shane. You know more about my tranny than me! Ever install a TW chip?
haha, shane have you ever dynoed your truck if you don't mind me asking? i have pretty much the same mods as you and i just havent been able to get on a dyno yet. Im hopin to see like 300hp 600 ftlb but you never know
