no overdrive - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-30-2008, 11:06 AM Thread Starter
mdkallam130's Avatar
Send a message via AIM to mdkallam130
no overdrive
when going down the road in my 250 running about 55-60 mph my rpms are running about 2300 to 2500. the truck used to run about 1700-1800 at these speeds. i know my overdrive is not working correctly. everything else seems to be doing fine other than not going into overdrive.
my question is what could be causing this problem? i had the tranny rebuilt in march of 08 so it dont have that many miles on it since the rebuild. i removed my tw chip as well to see if that was what was causing my problem but it still continued and ive kept a close eye on my transmission temperature and it has never got about 180* since the rebuild
any help or solutions would be greatly appreciated
2002 F250 Crew Cab 4x4 7.3
35x12.50x17 on a set of 2005 F250 Wheels
S&B air intake customized
4"turbo back straight pipe with a 5" tip,
gauges
DP TUNER - on its way
wish list.
5"turnout stacks,injectors,bigger turbo, bigger hpop, fass system, Built Transmission
"I'D RATHER BE JUDGED BY 12 THAN CARRIED BY 6"
mdkallam130 is offline
post #2 of 6 Old 07-30-2008, 11:39 AM
Conservative and Proud
Banshee34's Avatar
Quoted: 8 Post(s)
I can't help but think that the on/off switch in the tranny isn't working. Can't remember what it's called and all my paperwork is at home...
2001 F350, Lariat SC LB 4X4 PSD
Quadzilla Commander
Zoodad with Stealth Screen
The Org. Staff reserves the right to move, modify, delete or merge posts at our discretion and without explanation.
Banshee34 is offline
post #3 of 6 Old 07-30-2008, 12:31 PM Thread Starter
Yeah it keeps flashing.. but seems to have no effect when pressed in... i didnt know if if could be a torque converter problem or maybe a solenoid problem or what.
gauges
wish list.
post #4 of 6 Old 07-30-2008, 12:44 PM
Banshee34's Avatar
Quoted: 8 Post(s)
It's flashing??? Did you get an extended warranty when you had the tranny rebuilt?
Quadzilla Commander
post #5 of 6 Old 07-30-2008, 01:56 PM Thread Starter
Yean i have a 12 month 12000 mile warranty on it. i called the transmission shop and they said since its only been like 5 months they wouldnt even squabble with the mileage being even close to 12000... i just hope they dont try to pin it on the chip
gauges
wish list.
post #6 of 6 Old 07-30-2008, 02:23 PM
RadarRider's Avatar
The flashing light is a DTC. Get your hands on a scantool & you'll get your answer.
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
