Loss of mpg after getting stuck - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-27-2013, 07:35 AM Thread Starter
I went hunting two weeks ago in Colorado. Towing my camping trailer possibly 2.5-3k pounds. Hunting camp is at 9500' When I got there I loss traction in the snow and had to put it into 4wheel drive. Trying to get out I noticed the truck jumping in place as I was giving it skinny pedal. Never notice this before in any of my trucks prior to this. Also I could smell something was hot when I got there. Not sure if that's coming from the tranny or the engine. I had changed the oil the night prior.
After I got unstuck and got moving again and at the camp site. I turned the truck around and went to back up and all I could get was black smoke to roll out and the truck barely apply pressure to the tires. I had to rock the truck to get it to back up. Once I got it to move if I let off the pressure, I would have to restart the process of rock the truck forward and back to get it to move again.
Now on the way out there I went up in elevation from SLC to Co. On I-80 cruising at 75mph or just under 2k rpm and averaged 15-16.5 mpg.
On the way back I went on I-40 which top speed was 65. N but probably averaged 55 mph and got 10. Mpg. Now that I'm home and unhooked at at my normal cruising weight. I'm only getting 11.5 mpg.
My question are, did I screw something up in the tranny when I was stuck? or is all that normal because of the elevation? Or is the oil change part of my problem cause I used rotella?
Truck has 200k miles on it now. PO said that he had the tranny rebuilt around 100k mark. Is this a normal 100k mile rebuil?
Any thoughts would be appreciated.
gr8outdoorzman is offline
post #2 of 12 Old 10-27-2013, 07:41 AM
belz's Avatar
Quoted: 70 Post(s)
Have you checked your hubs to make sure they aren't stuck locked?
Belz
CPA Director
belz is offline
post #3 of 12 Old 10-27-2013, 08:09 AM Thread Starter
How do I ensure they r unlocked? Lift the front end up and spin a wheel? Hubs dial should be turned counterclockwise?
post #4 of 12 Old 10-27-2013, 10:37 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
if they are stock hubs they should have a arrow pointing which way to lock them.
jack up the front end with the wheels off the ground, if you spin a tire and the drive shaft spins they are locked in.
have you done any trans or transfer case maintenance?
trans case is often never maitenanced, it only takes 2 quarts of atf and 10 minutes to flush and refill.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 12 Old 10-27-2013, 02:34 PM
belz's Avatar
Quoted: 70 Post(s)
U should be able to just reach behind and spin the axle with the u joints in the hubs.
Belz
CPA Director
belz is offline
post #6 of 12 Old 10-27-2013, 06:14 PM Thread Starter
I had the wife who isn't colorblind to look at the trans oil. It's probably browner then it should be. So I will drain that and replace the filter. Anything else besides the trans case. Which I might as well do all at the same time.
And they r stock hubs, But they have no visible markings.
post #7 of 12 Old 10-27-2013, 06:18 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 79 Post(s)
Feedback Score: 7 reviews
If the fluid smells like cat piss, start saving your pennies.
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #8 of 12 Old 10-28-2013, 04:50 PM Thread Starter
Smells like maybe a slight gasoline smell, but r we talking like a litter box that has been used by a 15 cats and hasn't been changed in a month or a fresh litter box with a small fluffy kitten
post #9 of 12 Old 10-30-2013, 04:39 PM Thread Starter
What should I use for decron. Valvoline, Lucas, or Royal P? And what's the difference between decron V & VI?
post #10 of 12 Old 10-30-2013, 04:58 PM
BBBRRRRRTTTTT
Quoted: 79 Post(s)
15 kittens.
