P0733,P0782,P0733 - Ford Powerstroke Diesel Forum
post #1 of 1 Old 10-14-2013, 10:20 AM Thread Starter
jmercado5065's Avatar
Quoted: 2 Post(s)
P0733,P0782,P0733
My 01 Excursion shifts perfect from 1st to 2nd after shifting into 3rd it slows down like if brakes are applied. Scanned codes and p0733,p0782,p0733 codes are present. Already replaced the solenoid pack, checked for stuck valve on trans valve body, no shavings in the pan.The scanner shows the the transmission shifting from 1st to 2nd and 3rd but then is like if someone apply the brakes and no matter what else i try it wont shift, It slows down to a crawl. Thanks in advance
jmercado5065 is offline
