tranny acting up - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-09-2008, 05:33 PM Thread Starter
Adub90's Avatar
tranny acting up
My tannie is shifting very unconsistently and would shift in and out of o/d like it couldnt make its mind up??? and my o/d light is flashing on and off . i just had my transmission rebiult about 4 months ago with a trannie cooler and it just started acting up after i took an 11 hour drive. I was thinking it was a bad speed sensor what do you guys think ??? please help
early 99 7.3
Tymar
zoodad
4" straight pipe
banks big head
banks trans command
mag hytech tanny pan
315 nitto terra grapplers
rear end replacement
banks egt and boost gauge
DP-Tuner, no start, 80hp econo, 120 race
DIY boost fooler
ccv
Adub90 is offline
post #2 of 13 Old 07-09-2008, 05:37 PM
duct tape & zip ties
bigcountrysg's Avatar
I suggest you go back to the shop that rebuilt your trans. That is if you have a warranty with the rebuild.
Either way you will have to have codes pulled that pertain to the transmission. Which a normal code reader will not pull.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 13 Old 07-09-2008, 05:57 PM Thread Starter
Adub90's Avatar
I had it scanned at a transmission shop and the only code they pulled was internal control ram error I think is what it was
early 99 7.3
Tymar
zoodad
4" straight pipe
banks big head
banks trans command
DIY boost fooler
ccv
Adub90 is offline
post #4 of 13 Old 07-10-2008, 09:44 AM
sirnunya's Avatar
whoever rebuilt the tranny is who you need to talk to. 4 months? you're not exactly pushing high power, and it lasted less than a stock reman
sirnunya is offline
post #5 of 13 Old 07-10-2008, 10:49 AM Thread Starter
Adub90's Avatar
yeah unfortunatly I had the tranny rebuilt back home on Texas and I live in Arkansas now. Do you think my PCM could be the problem if its fried ?
early 99 7.3
Tymar
zoodad
4" straight pipe
banks big head
banks trans command
DIY boost fooler
ccv
Adub90 is offline
post #6 of 13 Old 07-13-2008, 05:33 PM
dereku's Avatar
Feedback Score: 7 reviews
Send a message via AIM to dereku
I know im a little late on this one but the trans coolers suck on these you have to either go all aftermarket or remove the lines from the radiator and blow em out with an air hose and some choke carb cleaner. I talked to brian from BTS and it worked great
dereku is offline
post #7 of 13 Old 07-14-2008, 01:20 PM
symbols's Avatar
I am having a similar problem with mine but mine only does that after severely overheating on long drives. What are your temps?
Jason
"Using a thug's murderous rampage to call for gun control is like using Barack's reckless spending to call for higher taxes."
--Michael Berry, American philosophizer & Talk Radio Czar, 1970-?
symbols is offline
post #8 of 13 Old 07-14-2008, 01:32 PM Thread Starter
Adub90's Avatar
Im not sure what my temps are because i dont have a gauge yet, i wouldnt imagine it would be to bad for one i have a cooler and two i have a mag hytech pan. But yeah ever sense this 11 hour drive my trannie hasnt been the same
early 99 7.3
Tymar
zoodad
4" straight pipe
banks big head
banks trans command
DIY boost fooler
ccv
Adub90 is offline
post #9 of 13 Old 07-14-2008, 01:51 PM
symbols's Avatar
Well, I have 2 coolers and a mag hytec pan also. My trannie is barely 2 months old and it got over 260 deg within 1-1/2 hrs of highway driving a couple nights ago with no load and about 85 deg ambient temp. So I think you can see it's definitely possible.
Jason
symbols is offline
post #10 of 13 Old 07-14-2008, 02:12 PM Thread Starter
Adub90's Avatar
damn. Well do you guys know any really good rebuilt shops that are relatively affordable I can't stand these damn tranny problems anymore
early 99 7.3
Tymar
zoodad
4" straight pipe
banks big head
banks trans command
DIY boost fooler
ccv
Adub90 is offline
