whisky6 - Ford Powerstroke Diesel Forum
Old 07-06-2008, 11:10 AM
whisky6
Hi,this is whisky6,i got the pieces of trans. sender out of port,now i have oil
coming out of port,installed new sender,but and took truck out for a run of
about 5miles and up a hill for about 1mile in low gear at 3000rpm,still can not
get any reading on gauge was this not enough distance&working engine to
get temp. up.
I have a bank,s trans gauge installed,can you get the wires reversed from
the tran,s or should there be only one wire from sending unit as i have 2.
Ther are 3wires to back side of gauge,there are 2wires at same level where
the tempature reads on front of gauge can you put these on reversed.
I do not want to reverse wires if can possibly destroy gauge,thank,whisky6
