ATS transmission went BOOM... - Ford Powerstroke Diesel Forum
post #1 of 54 Old 10-07-2013, 08:26 PM Thread Starter
Feedback Score: 3 reviews
Leaving work today in my 02 F350, pulled out in traffic and stepped on the throttle....boom, no more power to the rear wheels. It goes into Park, but any gear I select; reverse, drive, 1st, 2nd....I get nothing. Give it a bit of gas and the RPM's just shoot up, but no engagement in the trans. Tried shifting it into 4wd to see if it was the chain in the transfer case, but it wont engage because the transmission isn't turning.
So, Im guessing I broke something in the transmission, not sure exactly what though. Its an ATS transmission that had all the billet upgrade parts you can throw at it, the previous owner put it in just before I bought it. Its got about 120,000 miles on the transmission.
Had it towed to a local transmission shop where my buddy knows the owner, so hopefully they'll go easy on me. Im the type of guy that does all work on my vehicles, I just don't have the time to pull the trans on this truck.
Anyone have any ideas as to what it could be?
02 F350 7.3L Lariat; DP tuner, AFE stage II intake, AFE intake manifold, dual 4" exhaust, ATS trans, Autometer gauges, Superlift 8",
38" Toyos, 20" Provo's, Amp Powersteps, 05-07 Front end Conversion, KDfabworks bumper bracket with CSI 20" LED....
kjdavis is offline
post #2 of 54 Old 10-08-2013, 04:59 AM
JSchuricht's Avatar
120k out of a purple grenade is pretty good. When these transmissions go out you have to pull the entire assembly apart to check for damage. If your OD light wasn't flashing then it's probably the input or TC, if it was flashing then there was a code that might have given you a clue as to what the issue was.
JSchuricht is offline
post #3 of 54 Old 10-08-2013, 05:30 AM
over200's Avatar
Quoted: 5 Post(s)
Same exact thing happened to me last week...sounds like the torque converter broke!
2000 F350 CCLB 536 k+ miles still runs like a top!
Diablo chip, quickie pedal, valve body, Air Force One air intake, MBRP system, XD Diesels w/ MT ATZ's, KL5H Train Horns / Air Zenith supplied.
over200 is offline
post #4 of 54 Old 10-08-2013, 05:48 AM Thread Starter
Wouldn't the truck still move though? It just wouldn't be smooth power to the wheels right?
kjdavis is offline
post #5 of 54 Old 10-08-2013, 05:49 AM Thread Starter
Got the trans shop pulling the trans tonight to check it out. Hopefully its minimal damage. Don't think its the TC because it wouldn't shift into 4wd because the transmission wasn't turning.
kjdavis is offline
post #6 of 54 Old 10-08-2013, 05:58 AM
over200's Avatar
Quoted: 5 Post(s)
No it wouldn't move in any gear position including 4x4 other than rolling freely in neutral ...and it all happened the same exact way as yours. They just finished $3,582.00 otd
over200 is offline
post #7 of 54 Old 10-08-2013, 06:05 AM
bdtribble's Avatar
Torque converters can fail in a few ways but if there was no fluid coming out of the inspection plate and you can't hear metal grinding together from the same area, then it's probably not the TC.
bdtribble is offline
post #8 of 54 Old 10-08-2013, 06:51 AM Thread Starter
no fluid, no grinding. leaning towards input shaft but we'll find out tonight I guess.
any recommendations out there for a new input shaft? not sure I want to put another ats in it.
kjdavis is offline
post #9 of 54 Old 10-08-2013, 06:57 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
120k is good for an ATS trans! Hopefully you can get them to warranty their work like they claim everywhere you read about them... Probably not though
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #10 of 54 Old 10-08-2013, 06:58 AM
over200's Avatar
Quoted: 5 Post(s)
FYI I had no fluid coming out either it just broke where it engages at shaft... Curious to see if it was the same on yours ... On another note I did get 280,xxx out of that one which was #2 Keep us posted!
over200 is offline
