7.3 clutch problem - Ford Powerstroke Diesel Forum
Old 06-30-2008, 11:36 AM
7.3 clutch problem
i have a 2000 f250 4wd manual. i was driving home yesterday and was 5th gear for a while. went to down shift and the clutch pedal was hard as a rock. you can barely get it to the floor and when you do it wont shift. i pulled over and checked the fluid. it was full and when you pushed the pedal it would still push fluid. i got the truck home powershiftin and got on it in third and the clutch doesn't slip. my friend at monticello ford thought it could be a piece of the actual clutch that is broken. any input would be appreciated. thanks
Old 06-30-2008, 12:44 PM
nothing???
Old 06-30-2008, 01:17 PM
Thats Mr. Oil Leak.....
very well could be a broken pressure plate and/or bad shift fork...
Old 06-30-2008, 09:32 PM
it seems it is probly the clutch
