Trans won't shift into first at stoplight - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-23-2013, 07:06 PM Thread Starter
hpcbmw's Avatar
Trans on my 2000 F250 with auto trans was working fine until this weekend. I drove about 60 miles in the hills to go camping. Didn't push the truck or trans hard on the drive up or the drive back. When I got back into town, I stopped at a red light. When the light turned green, I gave it gas and nothing happened for a second. The engine revved, then the truck finally lurched forward. I'm not 100% sure, but I think it was in 2d gear. At the next stop light, I downshifted into first manually, and the truck ran fine.
Now, it seems to downshift to 1st sometimes, sometimes it doesn't. I checked trans fluid and it is just barely low. Trans fluid is red and smells normal. I think I changed the fluid about 2 years and 10k miles ago. I don't drive the truck other then to haul my camper or trailer, so it doesn't get alot of use. Truck has about 170k miles on it, I've had it since about 150k. I don't believe the prior owner had any trans work done.
Thanks for any ideas.
2000 F250 Lariat
4x4 extended cab
AIS intake
Stock tires/rims and everything else
hpcbmw is offline
post #2 of 3 Old 10-10-2013, 10:48 AM
GotSmoke01's Avatar
My truck was having similar issues, never took off in 2nd but would down shift and let it be known, and I lost the Intermidiate drum in the transmission yesterday. Not sure if that would be the issue you are having or not but, I have 178 on mine and it just did this, same thing happened on a buddy's truck in the mountains in ruidoso wasn't going very hard on it and the transmission just gave out.
GotSmoke01 is offline
post #3 of 3 Old 10-11-2013, 06:59 PM Thread Starter
hpcbmw's Avatar
I towed my truck to a local trans shop after it stopped running altogether. $3500 and a full rebuild later, I've got my truck back today. The shop says the internal center support gear went bad and I think they said was throwing chunks of metal into the fluid, causing other damage.
They had to replace the center support gear, which is not a normal part included in a rebuild kit. They assume the truck overheated in the past and spit out lots of fluid, causing the center support gear to go metal on metal and start deteriorating. This is as best as I can recall from my conversation with the shop today. I don't know much about trans (obviously) so don't know how accurate this is. This is a shop with a good reputation in a small town for 30 years, so I chose to trust them.
I'm moving my 30' 5th wheel this weekend, so hoping they put everything together well. Put 100 miles on it today and it's running and shifting well.
2000 F250 Lariat
4x4 extended cab
AIS intake
hpcbmw is offline
