Transmission won't go - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-22-2013, 05:35 PM Thread Starter
Dannyh's Avatar
Hi new to the form and searched all over for this and couldn't find anything.So my 2002 f250 7.3 automatic transmission has been giving me problems, basically what it's doing is when I put it in drive it doesn't want to move unless I rev it up. When I turn the overdrive off it works fine just lunges forward a little. Transmission temp runs about 180 in 90 degree weather. Also the truck has 210,000 miles and don't think the transmission has been rebuilt before. Any help?
Dannyh is offline
post #2 of 18 Old 09-22-2013, 06:34 PM
Quoted: 781 Post(s)
Is the fluid level good?
Corey@CNCFAB is offline
post #3 of 18 Old 09-22-2013, 06:38 PM Thread Starter
Dannyh's Avatar
Yea the fluid is good I thought that at first cause it did have a little leak but I've changed it and have checked it when it starts doing it. It seems to do it more when the transmissions warm
Dannyh is offline
post #4 of 18 Old 09-22-2013, 06:41 PM
Quoted: 781 Post(s)
Did you check the level while the truck is warmed up and running? If so then I'd say you pump is going bad followed by the clutches.
post #5 of 18 Old 09-22-2013, 06:47 PM Thread Starter
Dannyh's Avatar
Yea I checked when it is warmed up and running. I was thinking the same thing but wanted some other input before going to a shop. Thanks for the reply
Dannyh is offline
post #6 of 18 Old 09-22-2013, 07:04 PM
mazsecond's Avatar
Feedback Score: 4 reviews
Is the fluid dark brown or smell burnt? If not, probably your pump but you might as well go through it while its out and apart.
mazsecond is offline
post #7 of 18 Old 09-22-2013, 07:07 PM Thread Starter
Dannyh's Avatar
The atf that's in it I still nice and red doesn't smell burnt or anything gonna call tomorrow and get a quote
Dannyh is offline
post #8 of 18 Old 09-23-2013, 09:53 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Year>>>>>>>
CT Performance, Inc. is offline
post #9 of 18 Old 09-23-2013, 11:23 AM Thread Starter
Dannyh's Avatar
It's a 2002
Dannyh is offline
post #10 of 18 Old 09-26-2013, 04:43 PM
bigpanther2004's Avatar
did you try putting it in 1st or 2nd and seeing if it moves? could be a torque converter being bad too, also could of fried a clutch pack. Do you have reverse?
bigpanther2004 is offline
