Need a favor from someone with a 6 speed - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-11-2013, 02:44 PM Thread Starter
JSchuricht's Avatar
I have a ZF6 that's been sitting in front of my 95 for way too long now. I ran into a dead end trying to find the spacer plate. Ford no longer makes them and every junk yard I have called doesn't have them.
I have checked every thread that I could find and it's either 1/8, 3/16, 1/4 or 10ga thick. If anyone with a ZF6 can measure the thickness of the spacer I would be vary grateful.
JSchuricht is offline
post #2 of 14 Old 09-24-2013, 10:42 AM
BrodieBiking's Avatar
I will be doing a ZF6 swap next month, i could let you know later if you aren't in a rush.
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #3 of 14 Old 09-24-2013, 10:55 AM
bdtribble's Avatar
I have a zf6 but I'm afraid I'm not sure which spacer your talking about.
bdtribble is offline
post #4 of 14 Old 10-06-2013, 01:33 PM
Quoted: 14 Post(s)
I have a zf6. Which spacer are you talking about specifically?
ttyR2 is offline
post #5 of 14 Old 10-06-2013, 02:01 PM
timmyboy76's Avatar
give me a second, JS....gotta measure with tape though, since no mics here.
mines' 3/32...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 14 Old 10-06-2013, 02:40 PM Thread Starter
JSchuricht's Avatar
Thanks. I ended up making one out of 10ga which I am hoping is close enough. Hopefully will find out tomorrow. Trans is bolted up to my 95 and the pedals are in place. Might be able to take if for a test drive in front wheel drive tomorrow if I get the hydraulics sorted out.
post #7 of 14 Old 11-11-2013, 07:27 PM
I think that plate aligns the starter so hopefully you got it made right. When I did my swap I was able to find a shop near me to order one. It was a ford part and brand new and not too expensive. Maybe like $40. Might be worth checking with a shops to see if they can order one.
Matthews is offline
post #8 of 14 Old 11-11-2013, 10:11 PM Thread Starter
JSchuricht's Avatar
Ford was my first choice but only one space was listed in the system and that dealer couldn't find it. I don't think the spacer aligns the starter. the three bolt holes pass through the spacer into the bell housing so it can't really be adjusted. Either way, the plate I made has been working fine. Thanks for the help.
post #9 of 14 Old 11-12-2013, 06:13 AM
timmyboy76's Avatar
OT...but, how's the progress?
post #10 of 14 Old 11-12-2013, 09:59 PM Thread Starter
JSchuricht's Avatar
The truck is up and running, currently have a few hundred miles on it. Only thing left is to finish up the front drive shaft and shim the carrier down some more due to a vibration around 70mph.
