trans will go into gear but not move - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 Old 09-11-2013, 07:39 AM Thread Starter
So on Monday while at a stop light I pressed on the throttle and truck would not move. After a small panic attack because I was blocking about 70 cars I turned it off and then restarted pit into gear and it moved. Did this all the way home. Now while in driveway sometimes will move sometimes will not. It seems to go into gear because I can hear idle and Rpms change. Just will not move. I have just recently replacedlm flexplate but has been fine for several weeks. I am hoping it is something simple and cheap for I start new job monday and have little funds at this time. I also have problems with powerwindows, I do t know if the trans and powerwindow share the same circuit. 2 out if three relays seem to have issues and it seems that while messing with it sometimes it will move. Idk. Maybe just my mind thinking it. Is related.
jchaussee is offline
post #2 of 16 Old 09-11-2013, 11:35 AM Thread Starter
Curious if anything electrical?
post #3 of 16 Old 09-11-2013, 11:37 AM
ZMANN's Avatar
Quoted: 1597 Post(s)
2 things to check
fluid level
your converter bolts came out ?
We Miss you Ronnie
ZMANN is offline
post #4 of 16 Old 09-11-2013, 12:16 PM Thread Starter
Fluid level is good. And do you mean the nuts that hold flexplate on to converter. They all there but maybe loose. I will check.
post #5 of 16 Old 09-28-2013, 12:33 PM
hpcbmw's Avatar
JC, any luck figuring this out? My truck is having a similar issue.
2000 F250 Lariat
4x4 extended cab
AIS intake
Stock tires/rims and everything else
hpcbmw is offline
post #6 of 16 Old 09-28-2013, 12:54 PM Thread Starter
Yes. I believ it is my transfer case
post #7 of 16 Old 10-17-2013, 08:53 AM
Whited35's Avatar
My truck did the same exact thing. What did you find in the transfer case? I thought it might be an electrical problem.
Whited35 is offline
post #8 of 16 Old 10-17-2013, 09:00 AM
Whited35's Avatar
Here is another concern I have, I just swaped out my stock torque converter for a Hughes Billet converter 400 miles ago and now I'm having problems. Any other ideas?
Whited35 is offline
post #9 of 16 Old 10-19-2013, 01:21 PM
I had the same problem, Brian told me to check to see if the filter was clogged. I replaced, now just running hotter than usual.
HSV_sd is offline
post #10 of 16 Old 10-19-2013, 06:34 PM
usteffenhagen's Avatar
Since we're on the topic, how long roughly does it take for your transmissions to shift into reverse from either park, neutral, or drive?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
