Trans slipps when cold - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-10-2013, 11:36 AM Thread Starter
Here is my issue and I need some direction on what to do next. I have an 01 F250 with an auto trans (not sure the model of the trans). If I let my truck sit for a couple of days without starting it, then start it up and put it in gear, it acts as if the trans is slipping, or that it doesn't fully engage in to the gear that I put it into. If I start it up and let it idle for 10 seconds, it engages into gear like normal, and has no slip. I have checked the trans fluid, and it is full and clean.
What next?
Thanks for your time
))--SLIVER-->
SLIVER300WSM is offline
post #2 of 3 Old 09-21-2013, 04:28 AM Thread Starter
Bump..... Any ideas.
))--SLIVER-->
post #3 of 3 Old 09-21-2013, 06:27 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
It's a Diesel, it's a Heavy Truck, it's NOT your Honda Accord...
What are you doing starting it and throwing into gear in less than 10secs? Give your poor truck a break and let it run for a bit before you drop it into gear and ask it to initiate the forward movement of 3 Tons of iron
NoRalPh is offline
