4r100 wouldent shift 2nd full throttle - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-07-2013, 05:50 PM Thread Starter
Went to race a dodge the other day, it was really hot outside. Left the line around 10psi launch and got a jump on the dodge but when it came time to shift to 2nd the truck seemed like it went to neutral I let off the throttle and it shifted.
Could it be from the heat? Trans temps were at 155*. I bought the truck used and the owner before said it has a beefed up trans with a billit converter.
Can this be the valve body, or sound internal?
I got on the truck in the morning today and it shifted fine.
01 f250 4x4 supercab, 7.3 6" icon leafs all around king 2.5 remote res. 4" straight pipes turbo back, aem intake, 35s on 20" rims, ts 6 position chip edge insight cs monitor for the egts and icps. A pillar boost and trans temp gauges, riff raff billet wheel, banks intercooler, turbo master wastegate controller.
Justin_502 is offline
post #2 of 10 Old 09-07-2013, 06:09 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
155 degrees isnt hot for the trans
mine does this occasionally i think its the torque converter not unlocking, but i could be wrong.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 10 Old 09-07-2013, 06:33 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Sounds like the tq converter. But could just be worn parts in the trans. Mine did that before I built it.
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #4 of 10 Old 09-08-2013, 06:53 AM Thread Starter
I don't have the extra cash for a trans right now, have a 5month old baby. I guess I'll have to take it easy on the truck and drive normal!
post #5 of 10 Old 09-10-2013, 05:21 PM
Mine did that. Then I pushed it too hard and blew it. I know the center support being loose can cause this (or so I was told [i also had slipping in 3rd and 4th when floored for a good 5 miles or so]).
So you might be able to retorque the center support and it might help.
Trucks:
2000 f250 xcab sb 7.3 4r100 242k
Banks full exhaust, egt's and boost, 6673, hutch/harpoon, and toyo open country a/t's (285x75x16r)
1995 Bronco 351w E4OD 192k
K&N "cold air", 12 KC lights, 3" bl, 33's dick cepek mud country's.
catsnw is offline
post #6 of 10 Old 09-10-2013, 05:38 PM Thread Starter
Is the center support where the back trans mount is? Ill go check make sure all is tight.
post #7 of 10 Old 09-10-2013, 05:39 PM
Doesn't Even Care
Quoted: 69 Post(s)
no, the center support is inside the case. mine was broken too, when I got mine built they found it.
Nick
"The Mistress"
post #8 of 10 Old 09-14-2013, 06:18 PM Thread Starter
Checked the code today it it had the typical p1211, p478, and a new code that came on is p720.
Can that 720 speed sensor code cause this issue with shifting out of first? I'm going to order a new ford trans filter to replace before I drop the pan to check the center support bolts.
Also it shifts really soft, think if I had my ts chip sent out if they firmed up the shifts it would get it into gear?
post #9 of 10 Old 09-15-2013, 12:41 PM Thread Starter
Took off and cleaned the sensors, same problem...
post #10 of 10 Old 09-18-2013, 02:22 PM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 35 Post(s)
Did you do any work to the valve body recent?
How many miles are on the trans.
but if you're not getting the 2-3 upshift, might look at this video (sadly with bad audio) for the 4r100 rebuild.
Could have been a stuck valve.
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
