Trans stuck in 5th gear after pcm swap - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-29-2013, 06:43 PM Thread Starter
I have a 2000 f250 7.3 with an auto trans.
I recently replace the pcm with a remanufactured one from Oriley's. had the pcm flashed and now my trans is stuck in 5th gear. The trans shifted fine before my friend fried my first pcm installing a chip. What could be the problem?
Hville814 is offline
post #2 of 5 Old 09-02-2013, 05:15 PM
bigpanther2004's Avatar
For starters there is only 4 gears, and it could be possible that its programmed for a manual trans, what's it doing exactly?
bigpanther2004 is offline
post #3 of 5 Old 09-05-2013, 08:04 AM Thread Starter
Found the problem. Oreilly's sent the pcm for a manual trans. Now I need to know what kind of damage it has caused to my transmission. It was pouring out trans fluid.
post #4 of 5 Old 09-05-2013, 08:16 AM
Check the fluid level, put the new pcm in and see what it does, don't see that it would hurt if you only had it in for a short time.
post #5 of 5 Old 10-06-2013, 12:37 PM
Quoted: 14 Post(s)
What does "pouring out trans fluid" mean exactly?
ttyR2 is offline
